What brand or part # LED flasher relay?
SleekRunner
Title pretty much says it all.
Ive been trying to find the part # for a good LED flasher relay.
Any brands you recommend using or staying away from?
I ordered one from VLEDs but it is for newer toyotas and they dont have the one i need.
I looked on autolumination and superbrightleds but dont know which one to get.
I already have my leds sitting in my room but cant install them because of hyper flash and when you hit the brakes it will make your blinkers light up with the stock relay...
Thanks for any help.
go to napa and order a "NF. ep35L" with this relay you dont need the adapter thats on the stock one OR you can order the "NF. EP34L" with this one you will need to use the adapter and trim the old relay and secure the adapter to it somehow....( ive tested both and both work)
This thread helped me out and I just wanted to confirm that EP35 is correct. It does specifically say led on the relay. Got it at advance.
I installed an addicted offroad front bumper and got some led turns to replace the stockers since they were in the stock bumper. They flashed horribly when first installed and I didn't want to mess with the resistors. Had the relay in and dash closed up in 10 minutes.
So if you are doing led turns, save yourself the trouble and replace the relay instead of installing resistors.
I bought a Tridon EP35 flasher relay and I still have fast blink action, what gives? I have LED turn signals for my aftermarket bumper.
