What can my V6 pull? Help!
sant6236
Hi guys.
I am wondering what I can tow with my V6.
I need a to hook up to a trailor this wknd to move a friend, and I am concerned to pull this thing. I believe it is 12' long.
What are your recommendations? What is the tongue weight, etc?
i have a 14ft utility trailer that i use 2 days a week to haul debris to the dump so the trailer is roughly 1250lbs and i haul sometimes up to 2tons with no issues what so ever so your golden!
I dont remember specifics but in your owners manual on page 400 is the weight capacities, I was just looking at it the other day.
(well page 400 for 2005, just check the specifications, should be last chapter before index)
I agree, read your manual. Find your engine option, and there should be a tow rating listed.
As for Toyota.com, they say a 2WD SR5 (you didn't say 2 or 4WD) with the 4.0L six is "rated" to 5000lbs. I presume that to be a gross rating: trailer + payload should be <= 5000 lbs.
Sounds about right, my V8 4WD is rated at 7000 lbs. I towed a 4800lb load with it last weekend, about 70 miles round trip, and it performed just fine - but cost me some MPG of course.
If your estimated total load is going to be over 500-750 lbs, I'd definitely follow the general rule of towing in Drive and NOT tow in Overdrive. Your transmission will thank you.
you'll be fine. 12 footer with 1800 lbs in there:
8153172420_ORIG.jpg~original
:D
what type of mpgs were u getting? i'm curious as to the difference in fuel economy towing similar loads with a smaller engine. will the v8 be more efficient in that situation?
I used my '04 V6 4WD to move a 6'x12' U-Haul trailer this summer... drove from MI to SC without any problems at all, save for a hit on the MPG. Normally I get ~22 MPG with pure highway driving; I averaged about 16 for the trip. Not too bad if you ask me. I'm not sure how the V8 would do, but I think it wouldn't take as big a hit towing a large load like that.
