What Color Paint for Center Caps?
desertred
Member
Did a search with no luck on the results. Can anyone tell me what brand/color paint will match the OEM wheel color? I need to repaint my center caps on my 2001 4Runner. TIA
I got a near perfect match using Dupli-Color platinum silver. The metallic silver matches well too but is very slightly darker. Either will get the results your looking for, just spend some time on the prep.
What did you do to prep the center cap? I was just planning a little light sanding with fine grit paper to create a bonding surface, spray the paint, and follow with some clear overcoat. Is there something else I should be doing? The caps appear to be plastic.
duplicolor makes an adhesive promoter that really helps when painting plastic. definitely wouldnt hurt to use some of this after sanding and before color coats.
