What could go wrong?
SCRunner12
I originally posted this in the classics section, but I think I will get more responses here. I went 4wheeling the other weekend and found some deep mud and water holes to play in. I know have looked into the things that could go wrong with crossing water and mud in a stock t4r.
Here is how high the water/mud was.
61540_583447260113_26203964_33367610_2797988_n.jpg~original
62765_583447195243_26203964_33367606_6101110_n.jpg~original
The differential can get water inside of it, which will cause issues down the road is my main issue. I'm going to extend the breather lines for both the front and back this weekend and hopefully drain the diff fluid.
What else should I look into. My t4r has been sounding like it has a scraping or humming sound in the engine. It gets louder when I accelerate. It sounds like it is coming from the belts. Is there something I can spray on there to grease it up? I really hope I don't have to take them apart and clean them.
About the diff breather, I read that the Nissan breather works well. Is this true for all t4r?
Any help would be great, seeing as I'm trying to make another trip out in a few weeks.
Although it's a lot of fun.......that mud will eventually cost you some big money. It EATS seals and bearings for lunch. The best you can do is clean, clean, clean after being in the mud.... take it from me....the fun ain't worth all the work.
You gotta be more careful about going into mud holes that deep without a snorkel. You probably sucked muddy water into your intake. Your pulley bearings probably also have a bunch of grit inside of them now, that would be my guess for the scraping noise. Go around with some WD40 and see if it quiets down. And remove the airbox and tubing and check for mud (or probably dry dirt now).
