What does "Rear Anti Lock" mean on a '94?
skywalker1020
My 1994 4X4 V6 T4R has a light in the instrument cluster that reads "Rear Anti Lock". It lights up momentarily with the other lights (like "engine check", "rear window", etc.) when I start the car. The light has never come on at any other time. There is no other sign that my truck has ABS. It sure doesn't feel like I have ABS when I drive on snow and ice. If I hit the brakes hard (usualy to test how slick the road is) I go into a full-on skid.
What does this light mean?
Does a 1994 usually have ABS?
Would I be able to feel something obvious when I stomp the brake on snow/ice if I did have ABS?
Thanks.
the light means that you do have just as it says: rear anti lock breakes. how long to you skid when you test the road and how fast do you go? i think it is safe to say that the abs on the older 4runners isnt as sofisticated as on newer vehicles, so it may not engage as quickly.
Well that's too bad, the 4 wheel ABS works great on my Isuzu Trooper, whether it's in 2wd or 4wd.
ABS is great if it's implemented correctly.
I'm still trying to find the rear ABS module or I think It's above the rear differential
Not sure about the module but the relay is tucked up by your front wiper motor on the passenger side of the engine bay, mounted to quarter panel.
