what exactly does ect mean and do
same thing as the SEARCH function :) just kidding
LINK 1 tells what the ect button is and what it does.
LINK 2 also tells what it does and what it is.
LINK 3 and finally link 3 here tells what the ECT power button is and what it does.
in case none of the links work:
peter78 said:
The ECT button raises the shift point of each gear on the transmission. The transmission shifts at a higher RPM compared to the regular mode. It is suppose to give you more power and is good for things like towing, driving in the mountians and just general 'hot dogging it'. In general your gas mileage should be slightly lower.
If you light pops up in the dash and then goes away each time you hit it, that is not normal. It should stay on when it is on and stay off when it is off. I bet the ECT still works, now the question is "When do you have ECT on and when do you have it off?".
I would go to a flat road and accelerate at a steady pace and notice were the transmission shifts, (at what RPM), then stop and hit the button and try it again. Hopefully the shift points will be different.
