This is not an HID setup, it is just higher wattage. The system looks pretty good because what you are doing is bypassing the stock power circuit and adding one that can handle the extra wattage. When you turn on your lights it activated a relay, which in turn completes a separate circuit. There're two things that are very important in this system; the separate power circuit is properly protected (fused) as close the battery as possible and the headlight fixture can handle the extra heat generated by the extra wattage. I wish I had seen this system before I went and bought better bulbs.
Koz
