What is behind this panel/compartment? (4th Gen)
ethernectar
Will eventually install a CB and wondering what is behind this compartment/panel pictured below. This would make an ideal spot, but I haven't been able to find out if this spot is even an option...
If it is an option, are there aftermarket mounting kits?
Thanks,
Matt
Oh, its an 06 Sport Edition.
if i remember correctly, behind that is the tube for the ac that goes behind your center console. i could be wrong though. but if i'm right, there is no space there to stick anything..
Hey man, Just put in an aftermarket deck in and I can tell you there is NO room behind that for a CB. Have you thought of a single DIN stereo with the CB under it?
Thanks guys, will have to look for a different place.
Don't want to take out the factory deck right now (Its the JBL one and sounds good). Just ordered a BajaRack setup so I spent my fun money. :)
I *THINK* you can pinch in both sides of this compartment and it will pop out.
DISCLAIMER - The author of this post assumes NO responsibility for damage incurred while taking the above mentioned steps.
You are right, except you don't have to pinch the sides, just pull upwards and then out. That won't help though because there is a back plate back there that hides what else is back there.
To the OP: There is no room back there for a CB unfortunately :( The only thing that compartment is good for is iPod connections or two rounds of 00 Buck :D
Depending on the size of the CB there are some areas with space, just not there. In-between the shifter & cup-holders and behind the shifter between the shifter and the center storage has "some" space. I put my extra radio modules in this area.
Overall though, in the dash there is minimal space to be had for anything at all.
