what is causing this noise ??
Mellemel
Guys, I have had a howling from the rear for about 9 months now only on accel between 55-70km's.
Today I had it at the garage on the ramp with the stethoscope listening to the axles at the ends and the diff.There was no bearing noise from the third member/ pinion bearing area, so that was ruled out.
The noise is coming from the rear passenger side, a wheel bearing possibly ! however, the bearing is not loose, there is zero play nor is it generating any heat, it will make a grumble sound if you physically spin the wheel with force, but the noise stops when you let it freewheel !
Could it be anything to do with the ABS sensor wheel in that location ? The ABS has never worked from when I bought the truck 3 years ago. The ABS dash light has been on ever since,
I have 387,000kms right now. 1997 V6 Ltd model.
If anyone can shed some light on this I'd be most grateful. Thanks.
Likely bad rear end seals. Diff fluid slowly works its way out to the bearing and washes out the grease and then the bearing noise.
I just did both sides on my 99 rear end w237k from info on this site.
seltzernator
