Depending where your from - the CDN versions have a tranny cooler with the V6.sharp4runr said:The 4WD V8s do have HI/LO selector, they just don't have a 2HI Selector like the V6 models. Normally the V8 would be in 4HI for regular driving...
V8 has a factory tranny cooler while the V6 does not.
spud72 said:Depending where your from - the CDN versions have a tranny cooler with the V6.
Uneek said:V8 has a weight distributing hitch (it's attached to the frame rails) rated for 7000lbs 4WD and 7200lbs 2WD.
V6 has a weight carrying hitch (it's attached to the last cross-member) rated for 5000lbs for both 4WD and 2WD.
sharp4runr said:Really? That's kewl! I wonder if it is installed at the port or comes that way from the factory...?
spyne said:Early '03 V8's have the weight carrying hitch. I think they changed over to the weight distributing hitch in V8's sometime around March or April of '03.
