what is the difference....
bigred528
between just a body lift with blocks, and a suspension lift. I know how it works but what will be the major differences?
ride quality is a major one that comes to my mind.
I cant say that my body lift made my ride any worse, but I bet just a 3" body lift would eventually feel awful compared to say a 3" susp. lift.
It makes sense to do things right the first time, so I would recommend a susp. lift over a body, or if you want to really do it right (w/ a 4gen and without longtravel) then do both!
If i had to do it over id get a 1.5-2" BL instead of just 1"
one lifts the body off the frame, and the other lifts the frame and the body with longer springs and shocks (ie - bettar)
You're contradicting yourself, you know how they work but not the difference?
A body lift raises the body.
A suspension lift raises the entire truck, and a good one results in more articulation.
That's a difference.
A body lift is fairly simple to install.
A suspension lift is more complex.
A body lift has no effect on the ride and handling.
A suspension lift effect's the ride and handling.
Re: Re: what is the difference....
no I was saying that I know a suspension lift is lifting the body and frame, and the blocks will just lift the body. I was asking what will the differences be as far as handling? or decrease in horsepower? acceleration? etc.
you wont experience any of that!
the truck will handle like it has a higher center of gravity, which is a change I enjoyed as it now drives,l ooks and feels like I would have liked it too stock.
If your debatine between the two, go with the susp., Old Man Emu makes really nice affordable stuff
DionicioLives
