what is this engine tick/clunk?
Lamer
I have noticed a small noise coming from my engine. the actual tick can be heard around the 8 or 9 second mark in the video below.
might need to turn volume up
Does the sound get louder and match with revving the motor?
marginally louder, but yes.
Can you tell if its coming from lower part of motor? Like from the hblock oil pan area? To me it sounds like a slight rod knock if it gets louder with rpms. Maybe others will jump in and see what they say. If it was me I would drain oil and look for.metal contaminates.
Is your car in gear? Mine made a “rod-knock” noise when it was in gear at idle. Took it to a reputable Toyota shop and they thought it was a cracked flex plate. They dropped the transmission and inspected the flex plate and nothing was cracked. They then suggested that a rod or bearing was going bad and that the noise was coming from the bottom end of the engine.
TL;DR- It turned out to be a bad AC idler pulley. I am crossing my fingers that your truck has the same issue.
-Dan
Start with the easy stuff first. Check your idler pulley. I've also read on this forum that having your belts too tight can cause this sound, but I've personally never run into this issue.
-Dan
They dropped the transmission to check the flex plate??? There's this great thing called an inspection plate... 4 bolts and it's off and you can see the flex plate to see if it's cracked... hope you didn't have to pay for labor.
I was lucky enough to not get charged for that labor. They felt pretty bad that I was potentially facing an expensive engine rebuild. I’m relieved that it only turned out to be a really worn out AC idler pulley. PHEW!
Sorry I havent responded to anyones tips recently. just got back from a trip to the UK for Christmas.
I plan on getting an oil change this week, its that time.
Has your timing belt/water pump, etc. every been serviced?
yes! actually it was done Sept 1st of this year (I believe for the first time ever)
Timing belt
water pump
crank seal
cam seals
drive belts
-Dan
This was not in gear. well, it was in PARK. Ill have to look at the AC idler pulley, fingers crossed.
-Dan
+1 with the idler pulley. Mine's been doing it for around 60k miles. I don't even notice it anymore.
I can still hear it in Park, but marginally. It goes up with RPMs, but isn't audible above 800-900 (which is why Park doesn't seem to make the noise).
this comforts me haha. I cannot hear it at any RPM other than idle.
Yeah it scared me too. Then I realized it seems to quiet down A LOT when turning the AC off.
So I tested that theory by removing the AC drive belt. No drive belt, no turning idler pulley. If my memory is correct, this is the outermost belt, so you don't need to remove the other 2 to take it off. It'll take you maybe 20 minutes.
I drove around for 2 days with no AC, and never heard the knock/tick once.
At the very least, even it's something worse in the AC system, like a failing compressor, it's a whole lot cheaper than a new engine.
hmm. I haven't run the AC is a while (its winter season) but I will try it anyway.
Even if you're set to heat, if the little 'AC' button is lit, the AC compressor is spinning, which will make the noise (if that's indeed the issue).
Also, when a/c is off there is a bearing associated with the electric clutch that spins. When a/c engages this bearing no longer spins.
There is a belt idler near the bottom of the engine that can fail, as well.
Well that's the more accurate, technical, in-depth answer. Ha.
