You are reading way to much into this. Check your short term and long term fuel trims. If they are good (close to 0) and you are getting reasonable mileage, everything is fine.
-Charlie
it's possible... but here is what I know as facts...
I have a 97 4runner, stock, even tires...
My 99 was is my daily driver, before the lift and tires... I got 15mpg vs the 97 getting 18...
1- both are the same, except the gear ratio (4.10 vs 4.30)
2- the 97 accelerated and still does, faster than the 99
3- I understand bigger tires will hurt mpg. I am running 285/70 r16 (odd size from nitto trail grappler's M/T) and I'm now down to 14-15mpg... ok I'm at 14mpg.
4- my wifes 97 has stay consistant, 18mpg, mixed driving, and trust me when I say she's 'always' in the throttle... and brakes later. she shouldn't be getting that mpg, and when I drive it... I've reached 19mpg with the way I drive, and I drive both 97 and 99 the same.
5- both are auto's
6- both are 4wd's
7- mine does have e-locker... her's does not
8- 97 is Sr5 and 99 is limited, awd is off.
9- 97 exhaust smells 'good', for an exhaust smell... 99 smells bad, not 'rotten egg' or anything but 'thick' and 'over powering'... it just smells off... I have confirmed from two other 3rd gen 4runners I have 'test' drove from craigslist. they smell like the 97, one was 99 and the other was a 02
my lift is only 2inches, I've have read these forums and everyone I've asked is average 16 for 33's and 3 inch lift. I'm 13.7-14.5mpg
I bet if I took my lift back off and ran stock tires, the 99 would not get better than 16... freeway 17 maybe.
ok, so that's my facts...
I do have a new O2 sensor... it could be bad, but no code...
I do have new CAT's... yes both cats, both are walker from rockauto
I have done PM... sensors/intake/fuel/grease/fluids/filters/gaskets...
I'm thinking next injectors, possibly replace the auto-zoo fuel regulator ($160) I installed as a test... the stock one was better.
I'm thinking fuel, maybe i need a computer re-flashed... I've experienced that before in a chevy.
I'm not sure where to look at... the AFR is pretty darn close... and besides, if I'm really running 14.9+ wouldn't i get better mpg? just 'slightly' above?
idk, i might be reaching but i feel something is wrong, not catastrophic wrong, but something I want to fix. it's annoying me, and I want it gone.
