what size spacers for 4th gen. wheels
Einstein69
what size spacer adapters you guys think i should go with. i have a 3inch lift and 4th gen wheels 265/65/17 on my 97 t4r. they rub the control arm just normal driving around town and would def. not go 4 wheeling with them like that. recommendations???
i have somebody that said he would come buy them within the next two days, so right now the 6 spokes are on. if he doesnt come thru im just going to buy spacers to use them. not enough mullah to buy a set of wheels or tires.
so the 1.25 works just fine? how far do the wheels go out past the fenders with that spacer?
A 1/4" sandwich type spacer may be enough.
You are going to have to answer the "how far out" question yourself. With the wheel/tire combo on measure out 1.25" and that is where they will be. I'm not being a jerk, that is the only way you get a true answer.
Personally I would not wheel with that size wheel/tire combo. That is a short sidewall. The smaller the sidewall the better chance of popping a bead off the rim when aired down.
