BFEATHER2008
Just trying to get some ideas on what i should start with on my truck. It is STOCK. Thanks.
I would say lift...but that's gonna lead to wanting beefier tires, then wheels, and in the end you'll spend way more than $1000...LOL
I would wait on that 1000 and see what she needs. I just recently bought a 2000 and have spent a good deal of money just base-lining the fluids, replacing wiper blades, undercoat, etc etc. Just enjoy the ride for another month or so and see what it needs for the way you use it
How about making sure the belts and the radiator are replaced so you can just put the key in the ignition and start up without worries. That seems like the responsible thing to do.
Definitely some good advice here. I know, even though it would be great to get a mod or two in with that type of cash.
I would get some mud flaps($40 tops), tint match the front windows($95 is common price around here), and do every bit of preventative maintenance I could.
Check out Toyota Owners - Official Toyota Owners Website and see if there are any maintenance records on there.
You have a truck that is fully capable of most things stock and will last for a good while.
I'd bank it. Boring, but there's no better feeling than knowing you have something to fall back on.
I just purchased mine also. My first 1000 is all maintenance items. Transmission cooler, filter change, and flush. Timing belt, water pump oil seals. drive belts, brake flush. All the likely, neglected maintenance items. They deffinately add up quick plugs and wires were like 80 I think.
Tundra brake upgrade. You can do the 199mm on stock wheels, and it's only about $300.
You could also do wheels and/or tires first, then lift it when you have more money. I can't remember what the largest tires that will fit on stock are though.
You could do a lift, but you wouldn't have enough left for new tires unless you just got new springs, and I'm not sure how well that would work with stock shocks.
It's hard to recommend things though without knowing what you want to do. I think your best bet would be the Tundra brakes and bank the rest, or just bank the whole thing.
Thanks Geolander, i may go ahead with the tundra brakes i forgot about that lol. I would like to make into a a good trail rig. it is not locked or anything yet. i do want to lift and new tires and rims, sliders front and rear bumpers but im going to fab those myself, and lock it front and rear. oh and this is my daily driver.
I would do the tundra brakes, then start with armor if you want to make it more trail worthy. Check out skid row, budbuilt, lil skip's.
I feel like unless you are doing rock crawling, you are going to break it first by hitting stuff on the underside. Both armor and a lift help with that, so I'd say either is a good start.
Front bumper and winch would be another good option.
