What to know before buying
Franks4runner
Hi all,
New to the site. I am thinking to get myself 1999-2002 4Runner for daily ride and occasionally towing a pop up camper.
What do I need to know when looking for one? is the year make any significant difference? what year is better equiped for that purpose? anything I should be concerned of with 4Runners?
Frank
We need a sticky if there isnt one. I asked this and never got much reply. If auto then servicing for that but, if manual then clutch disk thickness should be inspected if high miles. There should be an inspection plate. Timing belt intervals are 60k but, I just found out these are not interference engines so it will not be catastrophic if they break. I would adjust the price about $700-$1000 if you can talk them into it for a forgotten timing belt/wp maint.
Tires arent cheap. Regular maint like oil changes should be documented. If not then an inspection of the curent oil condition.
look for leaks underneath. Engage 4wd to test. ask the person how often they used 4wd(they should tell you it was engaged every month to keep it working) Look for general condition and get a sense from the seller if he took pride in his vehicle or if it was neglected. Thats not something you can ask so much as deduce from them. Make sure all the windows work. Rear window should go down with remote. Open all the doors.. operate everything. Run a carfax but, look for collision damage anyway. Dress to get on the ground and get underneath and look at the frame rails front and rear. Start it and let it idle for a while while you talk to the person. Look for mud packed in everywhere. Not a problem if they were honest but, if you see mud and they said never off road you know they will lie to you. It should track straight down the road when you drive down a straight road. You should pick one with out as much crown (causes drift right) Ask for records. Lots of records and one owner are good. fewer records and two owners less good. no records, 6th owner and just bought it but, need to sell is suspicious...6th owner found the problem that everyone else before has sold it for..Lots more I'm sure.
Franks4runner said:
Thanks for the info. but do you think 2 wheel drive is easier to maintain? or do I need 4wd to tow?
Frank
2WD is easier to maintain. You dont technically need 4wd to tow but, it might feel more stable with the extra weight in the front. There were some reports of a floating feeling on the front of 2wd that was towing. 2WD might be hard to to resell in many areas.
a little more info
The manual is not available for all those years. I think it ended in 200. If I remember correctly the timing belt interval also changed around then. My 2001 is 90k miles. I don't think 2 or 4wd is better for the towing but I would get 4 if possible. I would also make sure I get one with the 16 inch wheels which had larger rear brakes.
is the 16" wheel and bigger brake standard? does it come with a transmission cooler?? (was told good for towing)
Whats the difference between SR5 and limited?
Franks4runner said:
99 Limiteds came with these wheels:
Those are not Limited wheels. Make sure to pull a carfax and look over the vehicle carefully, as it may have gotten in an accident.
That floating feeling may be caused by a high tongue weight. If the tongue weight is correct (10-15% of the trailer's gross weight), the problem can be solved by using a weight distribution hitch system, or WDH. A WDH distributes the weight of the tongue over all three axles of the rig rather than just the rear axle of the tow vehicle. Here's an illustration of the difference:
Hope this helps!
Looks like my 98 sr5 wheels
