What Wire Sould I Use?
1992-4r
What Wire Should I Use?
I bought a 3100 watt amp and two 1200 watt subs what wire should i use, do i need wire rated for 3100 watts...?
It's probably peak or max. No offense to you, but if that was RMS, I would think you would know what size wire to use.
I would go with 1/0 gague. This will hold up well with that current.
Im sorry, I thought i said what it was... 3100 is the peak power i don't know what gauge i should use because I couldn't figure out what the RMS was...
chances are its a legacy....i have a REAL 2000w rms amp and i run a 2awg JL kit with no probs...also fits perfect through firewall and through rest of 03+ 4runners
The manual should tell you what gauge wire you should use. If you dont' have it perhaps you can find one online.
Too small a wire could cause bad sound or amp failure.
I got the amp and it said to to use 8 gauge wire or better... so i bought the rockford fosgate wire kit (it had everything) from bestbuy, it is 6 gauge wire and then it goes to 8 gauge wire from the amp to the sub... it sounds great... everything is made by Lanzar... bought it off overstock.com and have a new HU coming in... unfortunatly put on backorder made by dual with touchscreen, DVD, HD radio, bluetooth, and ipod USB imput...
Cool. I hope the stuff lasts.
i have an update on the dual in dash deck i had ordered it off JCWhitney and the cancelled my order so now does anyone have any suggestions on what i should buy around the same price..?
What was the price? What do you want it to do? Do you need a wiring harness also?
www.ebay.com
Stick with a major brand, imo. I always go with Pioneer for HU.
