sfm7315 said:Need the advice of this group to advise me what brake set-up will work best on my 98' 4Runner Limited :
Brembo rotors with Akebono ProAct ceramic pads
or
OEM rotors with OEM pads
or has anybody have better performance with another combiation?
Advice is appreciated!!
mikehinthehouse said:man I smoked some stock rotors, then brembos in about 2 months each, do yourself a favor and do the tundra brake upgrade... do some searching you will find it
trd_4runnin said:I would say if you smoked some brembo rotors in 2 months then you either had already worn pads or you just are very hard on brakes. My 4Runner is just now needing new rotors and I've put about 15,000 miles on them, and who knows how many the p.o. put on them. You should start stopping earlier.
QSVeilside said:Our trucks rotors are notorious for warping for several reasons:
1. Overweight with undersized brakes
2. In most cases, our rear drums are not adjusted - http://www.yotatech.com/showthread.php?t=43741
3. Improper torque on the lug nuts cause the rotors to warp prematurely
4. Probably the most overlooked problem - IMPROPER break in period on the new rotors/pads - clearly stated ON the Brembo box.
Everyone that has gone with the Tundra upgrade have all claimed a signicant increase in stopping ability. The Tundra pads have greater surface area which translates to more friction, which translates to more stopping power... However, whether the Tundras are actually better at stopping than the stock setup is not clear. Why? The Tundra rotors are also significantly more massive and are the SAME diameter as the limited rotors = more rotational inertia = less stopping power. Somewhat counterintuitive... The good thing is, more mass = more heat capacity = a longer time to heat up. Hence, we haven't heard anyone on this forum or YT that has done the Tundra upgrade complain of warped rotors... which says a lot about our front rotors, their reaction to heat buildup, and the necessity to keep our rear drums adjusted.
Brembo crossdrilled rotors and stainless Goodridge G-stop brakelines have been on my truck for over a year now with ZERO problems. Break in period was followed. Proper torque on the lug nuts. Rear drums always in spec. Go figure.
trd_4runnin said:Good post.
I know that our brakes are weak from the factory and all of the things you mentioned make a lot of sense. That being said, I have put more miles on my stock set up then these guys are getting out of their brembo's and I have a hard time believing that a brake company trusted on many higher end cars including the mitsu evo makes shitty brakes. Maybe that's just me, but it doesn't make a lot of sense.
