what's the latest status on the 3.4 super charger kit?
xspsi6
I have an 01 and am seriously thinking about super charging it but I admit I don't know much about the kit such as where to buy and what to buy with it etc also in what way is the extra fuel getting in to the mix?
I seem to remember a 7th injector and also I have seen is300 injectors for 10% more fuel but it would kill my fuel mileage if there is no way to take fuel away at low load/cruising.
You can find them new online for $2,700-$3,000 and used for around $1,400+ depending on condition. A 7th injector kit will run you around a thousand bucks. Honestly though, if you're not trying to max out the hp and run a smaller pulley (especially if you run a larger one), you should be fine without it.
Ok thanks for the info so the stock fuel system will handle the trd supercharger with no additional mods?
I assume it would require premium fuel?
Yep they are designed for stock fuel systems assuming you have the stock pulley on it. How well they "actually" work with a stock fuel system though (amount of ping) I don't know. I will know by saturday though! And premium fuel is a must!
MikeV5280
