I'm looking at some Pro Comp aftermarket wheels, specifically the 1069 and 1079 series.
Both are 17x9" wheels with a 4.75" backspace. I don't know what the hub bore is but am checking with the vendor and/or manufacturer. Assuming the bore is ok (>106mm if I recall Harper7's advice correctly) they should fit with no need for spacers and be 1.75" closer to the outside/0.26" closer to the inside.
The 1069 is described as "Classic Design" and the 1079 is described as "Classic Bead Lock Design". There are Hub-Centric and non Hub-Centric versions of each wheel.
1079 Series Classic Bead Lock Design
1069 Series Classic Design
Can anyone offer insight into the meaning of the "Bead Lock" and "Hub-Centric" terms and how they might affect fittment for the '10 4R Limited 4X4?
My cosmetic preference would be the 1079 ("Bead Lock Design").
Thanks in advance
Thanks in advance
