Wheel Specs?
juiceboxer
I will be upgrading my brakes to the tundra calipers (231 mm (the big ones :biggrin2: ). I don't want to shave off any material from my factory rims so I am just going to buy new ones. Does anyone know the specific offset/backspacing needed to clear the 231mm calipers? Also what is the bore size? I am pretty sure they are hub centric and a 6x5.5 or 139.7. Any help or other info would be appreciated, Thanks!
The tundra rims that cover those calipers from the factory are a 17x7 with about 5" of backspacing. The lug pattern is 6x5.5. I'm not sure on the bore but most of the wheels will have a large enough center bore to fit Chevy and Toyota.
If I get a 17x8 rim do you think it will cause rubbing due to the increase in width? I know the Ivan Stewarts are 16x8 bit they are an inch smaller in diameter.
