Wheel Swap - Another dumb question
mtncrawler
So I've read and searched and think I have my answer, but I've also seen conflicting info, so I thought I'd pose a question for my exact situation.
I have the stock 18" limited wheels (18 x 7.5 ET24) and like many others, I want to swap out for a set of 17's.
I'm looking at a set of 17" Taco TRD rims (17 x 7.5J ET30). I also considered a fellow member's FJ's (which I would have preferred)
Am I correct in thinking that I should be OK - and the Tacoma wheels will stick out 6mm further or will these be 6mm closer to suspension goods? I also saw a set of 2014 4Runner SR5 (17 x 7J) wheel that have a 15mm offset. Do I need to consider backspacing?
I do have a Toytec 3" Ultimate Lift Kit and will be upsizing tires too.
Thanks and sorry for what probably is old news/question..:sorry:
The offsets on both these wheels will work in your favor. Both wheels will stick out away from the vehicle not towards your suspension...
Hey, thanks guys. It was a bit of a rushed week as I was trying to prep for a trip Friday, but I missed my chance because I ended up confusing myself.
I opted to go with a set of Cooper Discoverer ATP 275/65 R18's. I'll save the 17" swap for down the road.
I did end up buying a set of the 2011 Tacoma rims (as I was undecided at that point) - those are the 17 x 7.5JJ ET30's - compared with my stock 18" Limited rims which are 18 x 7.5J ET25's. I used the rimsntires.com calculator and I think I just misread things. (Prior to seeing the posts above). The side by side comparison showed the INCREASED backspacing (further away from suspension), but the notes below said that package 2 would be closer to suspension components...:ybrick:. Up against a time constraint, I decided to stick to the 18's
Anyway, I now have a full set of 5, 18" Limited rims with new Coopers! I can stick with them or sell them as a set if I choose. Interesting, but I think it would look a bit better with spacers. I thought I detected a slight rub when cranked all the way left (not right).
Thanks for the help :clap2:
