Wheelers Off Road SS Brake Lines - Anyone use em?
Check out Crown Performance.. $150 for front and rear but great quality and a lot more color options
Does anyone make front lines that eliminate the stupid metal tube between the hose and caliper?
Wheelers are $100 for front and rear... Are the Crown lines better in quality? Don't really care about color... black or red is good with me...
I'm not sure if they're better quality but they are good quality, haven't seen the Wheelers in person before.. I did it mainly cause I wanted blue to stick with my color scheme
most brands are the same made with Teflon inner line that carries the brake fluid, which is then covered with a layer of stainless steel woven braid than the stainless braided hose is coated with a clear abrasion resistant PVC cover for maximum protection against chaffing and strain relief devices reinforce end fittings... blah blah blah.... all the same just different brands and different prices, some may be made with "extra layer" but for us 4Runner we need 6 lines, yup 2 in front 2 in rear and 2 over rear axle, to feel a difference..
i have all 6 lines and i do feel the pedal is stiffer and that's pretty much it, less foot to pedal travel= firmer breaking
just my 2 cents.:biggrin2:
Save some money and get the stoptech SS lines from rock auto:
CENTRIC 95044007 - front lines EDIT: $32 for the pair (still way cheaper than $59 a pair)
CENTRIC 95044507 - rear lines - $46 for the pair
Or amazon:
Front - https://www.amazon.com/Centric-950-...=1479401505&sr=8-1&keywords=CENTRIC+950.44007
Rear - https://www.amazon.com/StopTech-950-44507-Brake-Stainless-Steel/dp/B0031HSCOA
Or from all-pro $34:
Brake Upgrades | All-Pro Off Road
Save some money and get the stoptech SS lines from rockauto
CENTRIC 95044007 - front lines $16
That would be a screaming deal, but its the only time Rock Auto has confused me with their pricing. It's $16 for one line, but since its a pack of two, its $32.
"+ Sold in packs of 2; Price reflects cost of each individual item, not the pack"
I have those lines front and back. They've been holding up fine for over a year now. Still haven't found the third pair that goes over the axle sold alone and not as a part of the kit.
Ah yea true, I have the SS stop tech front lines, I need to get the rears.
Here are the rear axle SS lines, not sold in a kit: FJ Cruiser Stainless Steel Extended Brake Lines - Rear
im not really interested in doing this, as I feel the braking is perfectly fine with the rubber lines, however that is an excellent price.
Goodridge is top shelf stuff.
A lot of us on here do it because when we lift our trucks it stretches the stock brake line out.. that's the only reason I ordered my kit cause I went through 2 hoses in 2 wheeling trips.
Well, looks like you win this thread...
I decided to go this route instead of the Wheelers lines...
Do you remember is this is a drop in fit?
Do I need to buy anything else?
No issues using all the existing brackets / mounts / line holders?
I've not used this specific kit but have used other goodridge products, they're good. Direct fit, nothing else needed, application specific. You can buy with confidence there.
BillM777
