Wheels and tires on a stock runner
wpsharpshooter
Im in need of some new tires real soon. I was curious as to how many folks have put aftermarket wheels an tires on a stock (non lifted) 4 runner.... Id like to lift mine eventually... But now is not the time... I would like to give it a more aggressive look with some wheels and tires though.... PICS appreciated
Whoever sells the wheels should have a infoon what they will fit. They should be able to tell you the size, width, off set and bolt pattern. Find a wheel you like, contact somebody who sells it and see if it can fit.
Well the crappy part is 265/17/70s fit fine on stock rims with minimal to no rubbing as soon as you put a rim with a different offset and that size tire on there they will rub. If cash is the issue and you aren't go to wheel it hard or very often and aren't in need of new shocks and stuts you can do a Daystar 2.5/1.5 spacer lift for around 140 and however much for install and alignment.
But if you plan on keeping the stock size tire just replace them and the rims then just ignore everything I just wrote lol
Id like to go a little bigger but... I dont really want to mess with my gas mileage, Dont want my speedo being off either. I wasnt really sure on the cost to do a lift. I was mainly wanting to see if there was any stock white 4 runners with aftermarket wheels. Im thinking I should go with a black wheel, but Im a little scared considering Ive always had chrome lol....
