when shut down the engine.......start boiling the coolant!
mimorepa
Hello how are everybody?
In my 1991 4Runner 22RE engine: I have the stated problem and the search of the solution procedure to start where the rule indicates ...... rectify the seat of the cylinder head, install the new gasket, check clucht fan .. . perfect, new water pump, new thermostat, radiator checked, hose, in perfect condition, no leaks, new radiator cap and ignition timing according to the manual ....... but when you shut the car, listening instant boiling coolant and pass into the reservoir.
In my review of various forum, I was referred to make the so-called t-block test: start the engine and the 30 seconds press or squeeze the upper hose (which runs from the thermostat to the radiator) and whether notes tense is an indication that there is a leak in the cylinder head to the cooling circuit.... in my case that hose under the pressure test do not observed this situation.
The temperature gauge indicates NORMAL OPERATING! and being seen on the engine, ALL related accessories and the cooling cycle are working according to the rule but something is wrong!.
I would like to thank any suggestions before proceeding to disassemble again to start the revision of the cylinder block or head for example to find internal cracks ........................ THANKS IN ADVANCE.
It is just the excess heat from the cylinders and blocks heating up the coolant in the block. It gets hot from the remaining heat and just overflows into the tank. This is normal because the radiator and water pump have shut off. It may sound like its boiling, but its just bubbling. If it is bubbling alot, let it cool completely, run the engine and take the radiator cap off. It should allow the air to bleed out of the system, and you can check the coolant level.
