where do i find my paint code?
keakar
i think i have the super white but dont really know and i need to buy a can of touch up spray paint
TIA
TIA
The paint code is on the VIN sticker on the driver's door jamb, unfortunately you will not see it say "paint" and then the code, the code on my 2004 is in with some other numbers to the right of the bar code and above where it says Made In Japan, the numbers on mine read as follows...yours being a 2006 the code could be in a different area of the sticker.
U2N210L-GKAZKA
C/TR ID4/LB42
A/TM AO1A/
A750E
MADE IN JAPAN
N0 122
The "ID4" is my paint code....Titanium Metallic
I think the code for Super White is 040
The code for "White" should be 056 which most likely isn't Super White.
U2N210L-GKAZKA
C/TR ID4/LB42
A/TM AO1A/
A750E
MADE IN JAPAN
N0 122
ok i see
C/TR 056 FB13
so i guess my code is 056 and its called just plain "white"
:thumb:
I recommend creating a free account at Welcome to Toyota Owners . Once you enter your VIN number you can actually print off the original vehicle specs which include the paint code and equipment. I keep a copy of the printed PDF in my glove box.
Sidenote: I've used toyotaowners to research vehicles I was considering buying because you can also view all work completed at a toyota dealership over the life of the vehicle.
2001ATL
