Where does this bolt go?
wmswords
Hello everyone, So i was replacing the valve cover gaskets this weekend and sure enough i have a left over bolt at the end of the project. Oops!
So who has a good guess as to where it goes?
I know its not one of the 2 bolts for the TB, and i took off the intake manifold to get to the VC's.
Now on a side note i want to thank EVERYONE here for all you guys do. i've had this truck for 3 months now and this site has been a wonderful resource. you people show how great a good community can really be. THANK YOU!!
2 nuts on the top on the studs, 2 bolts on the bottom 3rd bolt went were??
I had a feeling this might be the answer but i didn't see the hole on my quick skim sunday. Then again, I am human....so....
+1 on being a bolt for the intake manifold. It has been so long since I did this repair I can't remember if it is for the upper or lower part of the intake. Just look for a hole where a bolt should be.
Isn't there a bolt that goes under the top portion of the intake? The intake is two pieces and I think this bolt goes on the lower portion. When the top portion of the intake is connected, it is hard to see it. I just swapped an NA intake with a supercharger intake and this bolt is two different lengths between the intakes, supercharger bolt being longer. Look between your upper and lower intakes and see if you can see a hole in the middle.
or maybe the question should be , what is "izza"
is that pizza on the right hand of the list
other than that, intake manifold bolt
when you post a pic on the internet, I look at everything
Yep, definitely the one long bolt in the middle of the lower half of the intake manifold. You'll have to take off the upper half again to get it back in.
