Where does this ground go to? (Firewall) Pics
Trout_Bumz
So, Ive been wrenching all weekend...just updated the coolant system, and fixed some leaking valvecovers...
However...After finishing I cant get it to start. It will crank, but no fire...
Upon checking, I found this ground unconnected....
here is a picture of the ground...cant seem to remember where it goes.
One end connects to the firewall. Where does the other??
1995 4runner 3.0
IMAG0288.jpg~original
Sounds like a pain in the ass!
Check your main fuses.... You may have shorted something out while working around there...
I blew my main 80 amp fuse and nothing worked in the truck, no ACC power, dome lights... nothing, but it still cranked over.
It connects to that 12 mm bolt pictured in your picture. Bolts to the upper plenum.
You should check the fuses like walker suggested. It's easy to pop one. Check the EFI fuse, engine main, ect.
So, you removed the plenum to replace valve cover gaskets? Did you unplug anything to get the covers off? Maybe something isn't plugged back in.
I removed the UPPER plenum in order to get to the Passanger side valve cover. I have since taken it off twice to double check EVERYTHING. Everythings fine...I even poured some gas in the Intake tube...im just not getting any fire...Ill keep looking and post when i find out what it is :/
