Where is the brake booster line/PCV valve?
Mike Oxlong
Clueless about cars. My 95 4R is stumbling a bit at highway speeds. I've already had the plugs and wires replaced, as well as the cap and rotors. I'd like to try using that Sea Foam everybody talks about, but I have no clue where my brake booster or PCV valve are. Could someone clue me in? A picturee would be great but even a description would definitely help. Thanks.
the PCV valve is located on the passenger side valve cover. it is only accessible if you remove the intake plenum above it.
the brake booster hose connects from the front of the power booster to the left side of the intake plenum
Thanks for the help. Got it done last night; so far, no more stumbling.
