SilverBullet01
Senior Member
where do they house the flasher relay units on a 2001? ive been searching everywhere online, and i cant seem to find it in my rig. if you have them pictures would greatly help. thanks everyone
well i just went into autozone and ordered an electronic flasher. will be here in the morning. if not ill be placing and order for one of those.
not when you say it keeps ticking, do your turn signals flash as well during those 10 minute periods?
I was about to upgrade to LEDs for my turn signals in the next few weeks...anyway, so after seeing this thread i was unsure now...do the LED bulbs not flash correctly after putting them in?
You have to put a resistor inline with circuit to get it to function correct again.
It's because the LED's lower the overall # of Ohms in the circuit causing the flasher to "think" there is a light burned out.
now when you say it keeps ticking, do your turn signals flash as well during those 10 minute periods?
go figure, the electronic flasher did not work. Rock slide ill be ordering one of those soon
check out this thread i just found
post number 33 (im sure this time)
http://www.toyotanation.com/forum/showthread.php?t=199463&page=3
Pure genius. Can't believe I never thought of that.
I'm def going that route as the oem flasher unit is a much better quality unit. Now just to tear into the dash and get that aftermarket flasher unit out...what a pain that is.
So what other nifty mods are you gonna find for me that will make my current mods that much better. BTW, just ordered the parts the antenna mod.
now it is me that had not read enough. this is for an electronic flasher relay, not the stock apparently. so i still need a iso flasher. but im gonna try this trident one and modify it i guess
