where is the fuel pump fuse?
Jc12
So maybe i am a complete idiot and there isn't one, but i am doing a compression test and just want to shut off the fuel the easiest way possible, i checked the engine bay and in cabin fuse box.. anyone know or know another way to disable the fuel system for a compression test? Thanks!
If I'm not mistaken you can pull you efi fuse. I think it stands for electronic fuel injection is something it cuts off the power to your fuel pump.
there is a circuit open relay on the bottom of the interior fuse box. pull the the relay and the fuel pump will stop working.
will pulling the efi fuse work or do i need to do the COR, will it be the only relay in the fuse box.. just dont want to deal with another flooded engine (roomate's car) thanks :)
I'm 98% sure I pulled the efi fuse when I was fixing my first engine to do a compression check. You could always be double sure its stopped and clamp off the fuel lines in the engine bay.
COR is is to get to, only relay on the bottom of the inside fuse box.
I just barely did it today and it worked fine. However I did get a armpit full of gas which was a whole lot of fun.
044runner4
