Where to find a 3.72 Differental
fullspeed
Junior Member
Where to find a 3.73 Differential
My 99 4R has a 3.73 differential in the rear, but according to charts it should have been a 4.1 from the factory. Apparently a PO change it to a 3.73. Where does one get a 3.73? Is that aftermarket or what type of 4R's would have 3.73 stock?
My 99 4R has a 3.73 differental in the rear, but according to charts it should have been a 4.1 from the factory. Apparently a PO change it to a 3.73. Where does one get a 3.73? Is that aftermarket or what type of 4R's would have 3.73 stock?
How do you know it is a 3.73?
3.73 came in V6 2WD 4runners with the smaller base tire--225/75R15. Not sure about the 4cyl 2WD. I know my 96 V6 2WD 4runner has 3.73 gears.
also the door tag is meaningless.
Singtoe, good question. I jacked up one wheel and counted number of drive shaft turns for each wheel rotation and x2 for the differential effect.
I have three 4R's and this one had a different feel from the other two. It had a lot better acceleration from a stoplight and cruised better down the interstate and had better MPG. I have been trying to figure out why for a year or so. I had about decided it was mainly because it had an engine with less miles than the other two. It is also 2wd (the others are 4wd) but that didn't seem to fully explain this.
Finally, one day, I noticed it had a leak where the differential bolts to the rear end housing and also a couple of the nuts were missing. So I started to wonder if it had been removed for some reason by a PO.
Then it dawned on me to check the gear ratio. My 4wd's are 4.1 ratio and I was really surprised to find this one to be 3.73 ratio.
I was thrown off because the SS ratio chart based on model number (from maintenance sticky) and also another chart from another thread based on door sticker number both said it should have been 4.1
jmsdad, very interesting, that is good info about the tire size, I was confused on that from the SS ratio chart, that may explain where the PO got the differential from.
D Farms, good point. I think the SS ratio chart (Sonoran Steel, link from the master directory sticky) maybe better since it is based on a model code and it shows the stock ratio for the stock tire size (I was confused on that initially).
But all the charts are out the window if a PO has changed the differential.
I was surprised because this 4R seemed to be fully stock and it just didn't dawn on me that the differential could have been changed.
fullspeed, I agree, jacking up one wheel and counting the number of driveshaft rotations is the quickest method to accurately determine gear ratios. I've come across too many "online charts" and "door tags" over the years that were too inaccurate to rely on. Obviously, tearing down the rear end and counting the individual ring gear teeth is the most definitive method, but for all practical purposes, jacking up one wheel is the simplest.
To answer your question- Yes, 3.73s were stock gear sizes on some 4Runner models. My wife once owned a '99 v6 2wd auto w/ stock 225/75 (29") tires and 15" factory wheels. It had factory 3.73 gears. Within 2 months of ownership, I upgraded the tires to 275/70s (31") and the wheels to 16" knockoff oem 5 spokes. The vehicle looked 1000x better. We did notice a slight drop in mpgs and acceleration due to the increased weight/size, but within a week, we had grown acustomed to it. Aesthetically, it was well worth it.
FWIW, we sold the vehicle exactly two yrs later for $2K more than we paid for it. I was only out $500 for the tires/wheels (bought them both from a friend) and the only maintenance performed on the vehicle was regular oil changes. It's a real joy to own a vehicle that appreciates rather than depreciates.
