Does anyone know where on the firewall (From the inside of the car to the back of the engine bay) we can run all of our auxillary wiring? Are there any pics or info on this. Where are these holes located? I have a 2001 T4R.
Either A.) drill new holes or B.) run your wires through the same rubber boot as the stock wiring runs thru the firewall. If you look underneath your dash at the firwall, look up and over from the brake pedal. You'll see a bundle of wires going thru the firewall. If your wires are small enough, just run them next to the oem wiring.
If you decide to run some small wiring thru this boot, be sure to seal it up properly in the engine bay. I "thought" I sealed mine up when I ran some wiring thru this hole, but every time it rained the water managed to leak thru. I had to learn the lesson the hard way.
For some pictures of this wire bundle I'm describing and the how to on drilling new holes, check out this thread: Click Me
