Which Shifter Seat Do I Buy?
Been looking to upgrade my shifter seat, but I'm not sure which one I am to purchase. I ordered the White One for top shift transmissions. Is this right? I have been trying to search around for the transmission type, but came up with nothing. Any input is appreciated!
See here for the shifter seats I'm looking at Heavy Duty Shift Lever Ball Seats | Marlin Crawler, Inc.
From your link....
The White seat is for most other 1981 and newer common Toyota transmission applications with a direct top-mounted shift level, such as L-, G-, W-, and R-series transmissions with a shift base bolted directly on top of the transmission
I assume you have the v6 which would give you the R150F trans...... looks like you've got the right one picked out.....matter of fact if you had the 3RZ and the W59 it looks like you'd still have the correct one. :beer:
So finally installed the heavy duty shifter seat. As in the write-up (4runners.org) my seat was split in two as well. I can definitely tell a different in the shifting. Very much worth it. I would recommend it to everyone.
I was a little apprehensive at first on doing it on my own, but was very easy!
$10 for the shifter seat you can't go wrong.
