While doing the quick pre-winter maintance...did I miss anything
ryansmagic
Undercoating - 33 cans of ruberized undercoating....
spark plugs
spark plug wires
oil filter + oil
new tires
replace exhaust that has holes in it
check antifreeze(good for -36)
Fuel Filter
Air Filter
Am I forgetting anything? This truck will be driven all winter long and I don't want that "oh S***" moment because I forgot something.
33 cans of undercoating. wow how much did that cost?
Have you done lube
front and rear diff fluid and t-case and trans fluid.
Check all wiring- make sure its all covered.
serp belts.
check all light bulbs (signals and brakes.)
And make sure you have everything you need if you break down.
Spare tire
first aid kit
tow strap
and
:girl:
33 cans? You paint the frame or the whole truck? Never a fan of undercoat to begin with, never fully 'drys' and tends to hold moisture in my experiences. Definatly have a useful roadside emergency kit on board. Good jumper cables, flares of some form, can of sterno or other portable heat, usefull tools, working jack, etc. Hows your battery? Load test good? Charging system good? All hoses good and intact? No dryrot on any plastic/rubber parts anywhere? All I can think of at the moment that wasn't said yet
