2004 4Runner 4.0L – Recurring Misfires, Lean Codes and Suspected Head Gasket From 63,000 Miles Ago
realjeffedup
Couldn't quite find this exact issue on the forum yet for my vehicle. Forgive if there already is a thread.
I have a 2004 Toyota 4Runner Limited 4WD, 4.0L V6, with 221,773 miles.
I have extensive maintenance records from the original owner dating back to 2004. In July 2018, at 158,815 miles, he was experiencing similar misfire and engine shaking issues. Toyota suspected a head gasket beginning to leak.
However, the vehicle has been driven approximately 63,000 miles since that diagnosis, and I have no record of the head gasket being replaced.
Previous ignition and engine repairs:
  • June 2018: Six spark plugs, six ignition coils, six fuel injectors, intake manifold gasket, radiator, fan clutch, thermostat and housing reportedly replaced.
  • June 23, 2024: Purchased six Autolite Platinum spark plugs and two aftermarket ignition coils.
  • July 28, 2024: Purchased four Duralast ignition coils, part C1426-4.
  • September 9, 2024: Additional ignition coil purchased from Advance Auto Parts.
Current problem — approximately two weeks of troubleshooting:
November 15–16, 2026:
I noticed my coolant was low, the engine wasn't reaching normal operating temperature, and I wasn't getting heat inside the vehicle. I added coolant and eventually determined that the thermostat was faulty.
I replaced the thermostat, and the cooling system and cabin heat now appear to be working properly.
Around the same time, the engine started shaking and the check engine light began flashing intermittently. I'm unsure whether the cooling problem and misfires were related or coincidental.
November 19 — Advance Auto diagnostic report, 221,537 miles:
  • P0171 – Bank 1 lean
  • P0174 – Bank 2 lean
  • P0301 – Cylinder 1 misfire
  • P0306 – Cylinder 6 misfire (pending)
  • P0300 – Random misfires (pending)
  • P0430 – Bank 2 catalytic converter efficiency
  • P0500 – Vehicle speed sensor circuit
I cleaned and subsequently replaced the MAF sensor. The problem persisted.
November 24 — AutoZone diagnostic report, approximately 221,758 miles:
  • P0171
  • P0174
  • P0300
  • P0301
  • P0306
  • P0430
  • P0500
I replaced the PCV valve and discovered that the PCV hose was completely obstructed. I couldn't even blow air through it. I replaced the hose, but the misfires continued.
Over the next few days, I inspected the spark plugs and checked for visible evidence of coolant contamination.
I also swapped ignition coils 5 and 6.
November 28 — AutoZone, 3:30 PM:
The cylinder 6 misfire was no longer listed, and neither lean code appeared on this report.
I then swapped the ignition coils between cylinders 1 and 3.
November 28 — AutoZone, 4:49 PM:
  • P0302 – Cylinder 2 misfire
  • P0303 – Cylinder 3 misfire
The cylinder 1 misfire disappeared, but cylinders 2 and 3 started reporting misfires.
I've had the computer reset three times during this troubleshooting process.
I also cleaned the throttle body and replaced the engine air filter during this period, which made a substantial improvement in performance.
Before doing that, I could put the accelerator all the way to the floor, and the vehicle would barely respond or downshift properly. It now accelerates considerably better, although it still shakes while driving and occasionally flashes the check engine light. The rough idle has improved as well.
Current ignition coil configuration:
  • Cylinder 1 – Duralast
  • Cylinder 2 – Carquest
  • Cylinder 3 – Duralast
  • Cylinder 4 – Carquest
  • Cylinder 5 – Duralast
  • Cylinder 6 – Duralast
The cylinder 1 misfire appears to have followed the Duralast coil to cylinder 3. The four Duralast coils are only a little over two years old and have a limited lifetime warranty.
I've ordered six new Denso 673-1308 ignition coils, expected to arrive December 2.
Regarding the historical head gasket diagnosis:
I've checked for bubbles in the radiator, milky residue in the oil and visible evidence of coolant entering the cylinders. I haven't found anything obvious. The cooling system currently appears to be working properly.
What concerns me is that the original owner experienced similar symptoms and replaced many of the same components before Toyota suspected a head gasket in 2018.
Has anyone experienced anything similar?
Could I have gotten multiple defective aftermarket ignition coils? Could another underlying issue be contributing to the recurring misfires?
I'm also curious whether the clogged PCV hose, lean conditions and restricted intake could have contributed to these problems.
I'd appreciate suggestions on what to test next if the six new Denso coils don't completely resolve the issue. I'm trying to diagnose this properly rather than continually replacing parts.
How about an engine oil analysis next time you change your oil done at Blackstone. I don’t know if you use Toyota super long life coolant but if you do and it is a head gasket leak,, the potassium will most likely be higher than. normal.
Rialm
