Mine looks like hell. the paint is peeling in four different spots on each side and its all dull/faded. Just the main supports that run the length of the roof, not the cross bars. Has anyone refurbed one of these with good results?:frog:
I have the perfect solution for you. Just refinished the whole stock rack when i coated the frame and wheel wells this summer. I used Krylon fusion for plastic and with some basic prep a solid 2 coats did the trick. I'll get pictures tomorrow if you're interested. should take you no more than 3 hours taking your time. Its some of the best money I've spent on her I'm also doing the plastic valence below the windshield wipers.
I considered doing this too, but my only conern is what did you guys do for the endcaps since they're plastic? I can't painted the rails ok, but would like to match the endcaps pretty well too. Will the Krylon Fusion stick to the endcaps ok? Anyone consider line-X these parts, and if so, will lin-e work for the endcaps? Any help is appreciated
