While im there - parts replacement
yella
So, the time has come for me to start re doing my suspension. Going to do rear first, then front. But I also want to replace other wear parts while Im there. So what else should I replace?
Rear - springs, shocks, sway bar bushings and links
Front - springs, shocks, upper mounts, ball joints ( upper and lower )
The steering is tight with no play, so Im not sure that I need to replace the TRE's, but I might depending on cost.
What else should be replaced, front and/or read, while Im there?
^^^ Miles?
Why do you have to REDO the suspension? did you not use OEM at the first round?
I am at 209K miles in my runner. Except the shocks and rear springs every thing else is still original. Runs really good with no issues. The steering is tight like yours so don't touch it.
I was contemplating on bushings on my 00 Cruiser and saw few video's. One of the video from a reputed company said under engineered LandCruiser bushings.... we'll that's enough for me to move into a different video.... The truth is the LandCruiser is built with the help of nearly 1000 engineers in Toyota, and that is why it is the worlds most reliable truck.
282,000km. Everything is original.
First round? This will be the first round
Jhunt
