Whining Noise During Acceleration
Like Brad said about the stereo, even though the stereo is off, it can still produce engine noise. Make sure your power wire if you have an aftermarket amp is running down separate sides of the truck away from your RCA cables. Simple fix if its your problem.
And also a good ground has to be established...ie..scrape the paint where you ground it.
How does a stereo make noise when it's off??
Lol exactly... I'm sorry, but there is no possible way that the stereo is going to make noise when powered off...
In the same way some TV's will produce noise when they are not receiving input. I'm not sure if there is a fancy name for the isolators (hell, they might be called something that simple) but the produce some feedback into the system that comes through the speakers. If the wiring is really bad, it doesn't matter whether the head unit is on or off. I had that happen on an old F-150 years ago, $10 part and great sound... but it was still a crap truck.
If you say not receiving input on the TV, that can still allow for the tv to be "powered on". The sound comes from the 60 Hz AC power coming through a low quality power supply that doesn't filter that out, especially as you said on older analog boxes.
Either way, the stereo has to be powered on for these noise signals to be amplified, to then be sent to the speakers... If the stereo's internal amplifier is off - no noise.
Don't be sorry. I'm just saying you can never rule out magic or paranormal activity.
OP, let us know if you get that sound taken care of. I know how annoying those little sounds you can't pinpoint can be.
I had what seemed to be the same noise. Same circumstances, noise was only present when I was on the gas. It was driving me crazy. Exchanged messages with Matt and Kakrot, looking to see if they had resolved the noise. I finally got fed up and went all MacGyver on it. Wrapped my phone in a few layers of tape, put 4 neodymium magnets on it and wrapped it a few more times. I set the phone to record and stuck it to the frame rail next to the front of the transmission and went for a short drive. I kept moving the phone and recording until I was able to pinpoint where the noise was coming from. Narrowed it down to the transfer case or double cardan. Drained and refilled the transfer case, tested it out, noise was still there. Lubed all of the drive shaft/ cardan zerks, no more noise!
So that's the fix?
Nomadik_Overland
