whos looking to have Fluid film undercoating!!!
the rattle can jobs wont compare, as they are a lot more runny. the professional sprayer with the gallon allows you to put a thick heavy coat on and use the attachments to get inside the frame rails and other tight spraying areas withe the 360 deg sprayer. dont get me wrong rattle cans are ok but just not getting that thick coverage.
As someone who has done rattle can jobs on two vehicles I will say I agree with you. It took me five cans and while there is good coverage, it is runny, I have drips, and the coat is definitely not equal. If you were closer to me I would use you next fall (I pressure wash the old off and reapply every fall).
How do you clean it off in the spring? Pressure washer? I would be interested in having mine done but I’ve already been driving on salty roads for 2 weeks.
Pressure washer hooked onto hot water line...I hit it with Simple Green as well. I go through a bit of cleaner and crank up the water heater temperature, but the amount of dirt the Fluid Film holds by the end of winter is disgusting. It is black instead of its tan color.
If you get it done, you have to make sure to get all the salt off...that is why I do mine early fall...no road salt chances yet.
you can still have it done as i do a cleaning prep b4 applying it anyway. it typically will last a year. and you dont have to clean it off. it will continue to protect even in the summer months from water and crap on the roads.
message me for more info bud
the sooner you get the coating done the better for the vehicle
PM ME FOR MORE INFO!!!
I live a ways from you but get up to northern Jersey every once in a while to visit family. If I make an appointment, how long will it take to do the application and get back on the road? Thanks.
Steve did mine on Saturday.
Everything was fantastic, he sent me pictures of the process as he handled the undercoat and described the process as he went through.
As a huge added value there is a waiting room with WiFi and cold beverages.
Just got my 2018 ORP Fluid Filmed by the OP.
Nice thorough job. Great communication and adapted to my schedule.
Looking to extend the life through salt spray in PA and NJ Winters and using on the beach.
Sent from my SM-G892A using Tapatalk
