Murfe
I wonder if it ate too much mud?
I believe it may have. oops.
Shut up. Jerk. :clap2:
I bought my truck brand new from the dealer September 2011. Going on 6 years with my stock battery with no issues so far.
you should replace it before next winter, you are past the life of your battery
After a few days of driving it seems to hold a charge well overnight. Starts normally. So either I have a battery that won't hold a charge long term, or a some type of slow drain. I'm thinking it may be a slow parasitic loss from either the winch solenoids or my 12 Anderson style stub out. The 12v Anderson connector in the grill tends to get a lot of corrosion due to the fact that I soldered it to copper wires. Lead plus copper and salty/wet roads = corrosion buildup. Enough of that plus some salt and humidity and I think it could be enough to cause a slow drain on the battery. I think I'll give it a baking soda and scrub and test the solenoids and see what happens. Unfortunately it's a tricky thing to test without leaving it for a couple weeks.
Minihijack coming; but its scary to think what coke can do like cleaning corrosion off of a battery and yet we still drink it. But still, :cheers:
What is even worse is that Coke is used to clean blood from the streets. Also if you put a tooth in a glass of Coke, the tooth gets completely dissolved in 24-hours.
About 25 years ago I bought one of those roll around battery chargers from what is now Costco. I use it all the time to charge the batteries in various vehicles, lawn mowers etc. Best $50 I've spent in a long time.
Many years ago I worked in a service station for the summer. They had a Snap-on battery - starter tester. Connected to the vehicle it would read battery output, alternator output and charging rate. Also, you could crank in a load to how the electrical / charging system handled it. Many batteries will check good until loaded down.
[MENTION=118321]Jetboy[/MENTION] Why don't you just go to an Autozone and get the battery tested? Haven't you put it on a charger? Surely a guy with all your tools has a charger.
:lookout:
Use Coca Cola. Works better.
The factory Panasonic battery in my 07 FJ was still going strong when I sold it back in 2015. I wish there was a place to buy them here.
I like the Panasonic battery my 2012 SR5 came with. Is this the standard replacement Toyota uses in their service departments? It's been great since new but I don't drive it as much as some people so it's more of a time issue than a mileage one. I always make sure the water is up to the proper level. Or is Coca Cola better ?![]()
