B Bimmerod New member Jun 14, 2014 #1 Wanted to find out if 2011 FJ Cruiser wheels will fit a 2002 2WD 4Runner SR5 ? Tire size - 265/70/17 Will there be any rubbing issues ? Like these: Thanks, Bimmerod Last edited: Jun 14, 2014
mountain mike New member Jun 14, 2014 #2 Same bolt pattern so they will fit. Not sure if they will rub or not.
Nunyabiz New member Jun 14, 2014 #3 Mine work perfect. 2002 Sport 4X4 with 3" lift. 255/75/17 tires Attachments 4runner Kayak and Dwarfs cages 001.jpg 133.4 KB · Views: 4,613
B Bimmerod New member Jun 14, 2014 #4 Nunyabiz said: Mine work perfect. 2002 Sport 4X4 with 3" lift. 255/75/17 tires Click to expand... Not sure if these will work WITHOUT the lift though ??? Look great BTW
E ELock3rdGen New member Jun 14, 2014 #5 I have the 8 hole fj cruiser on mine before I lifted with no rubbing. If they are the same width (17x7 I believe)as those you won't have any issues with any rubbing. I also had the same tire size you mention and the side step on. Hope this helps.
busmup808 New member Jun 14, 2014 #6 Here is mines. 2 & 4wd are the same radius wise. I have 285s and they run only at full turn. 265s I had no rubbing.
