Will an Addicted Offroad rear bumper bolt right onto my 1996 3rd gen?
I thought I read somewhere early 3rd gens might need 2 holes drilled... but not sure why, or if that meant early-VIN '96s only... or even something.
Any advice?
Thanks,
Owen
Not sure about 1996, but you could easily check yourself. The part of the bumper that mounts to your frame has two OEM bolts coming in from the bottom that originally held in two tow points, and then two big bolts and nuts that come with the bumper that are supposed to go through two holes in the front of the frame that did NOT fit my 2000 ltd runner, it pretty much has to be welded on for me. Regardless, cutting IS required on the front of the frame, so it's not really a "bolt-on".
You must cut and grind front supports for bumper cross member to fit. Then step up drill bit needed to up size the original mounting bolt holes.
I though this was only necessary on newer 3rd gen ? Although mine, not addicted Offroad bumper. But savage, I did not have to cut anything of or modify. It simply bolted up. But Roy states that 99+ you must cut and modify.
OP call addicted and ask
Well I'm a 96 and have an AOR bumper so I know what's needed.
Scotty makes his mounting a lot more stout for strength and towing. Grinding cutting and drilling needed on all his bumper installs. Same when I installed one on a 4th gen.
Gotch ya
Owen,
I'd suggest giving Scotty a call and asking him.
The product description straight from his website says it's bolt on.
Tube Rear Bumper 4Runner (1996-2002) [aor-tube-rear(4runner 1996-2002)] - $654.00 : Addicted Offroad is a full service Parts, Sales, and Fabrication company offering offroad parts for all makes and models, Addicted Offroad
All these other yahoos are talking about the front bumper. :wink2: My guess is that the AOR rear bumper is a direct bolt on as stated on his website.
Owen,
Your right!! I was being a yahoo. HA.
THIS. I have this exact bumper on my '97, it was direct bolt, no cutting. But don't take my word for it! Smart move would be to call Scotty to confirm :)
Mine bolted on, but while one side is spaced perfectly from the body the other side is touching the body. Once I get my 4Runner mobile again I'll have to check with Scotty. It can only slide over the frame rails one way, so I'm not sure there is any way for me to adjust it.
Back bumper right ?
Correct! Rear bumper. Here are some photos.
My understanding that Scotty doesn't sell them out right, you actually need to drop off your vehicle for like 2 weeks?
