No, as I thought. You are one of the very few people that don't understand that certain modifications give the dealership and manufacture the right to deny warranty work. A lift is almost always accompanied by larger tires and wheels adding more stress to the stock parts. If those parts fail the warranty can be denied because your modification made them fail. You can't argue that a 33 or 35" tire doesn't increase the risk of broken CV axles, ball joints, tie rods, wheel bearings, drive shafts, u joints, your transmission, brakes, everything in your drive train. You can't argue the truth plain and simple. MM act won't help you either, MM act is to protect your ass from denied warranty work because you used a different brand of oil or changed your head lamp bulbs. NOT things like lift kits, significantly larger tires, custom tuning, super charger, cams etc...
