RkyMtHgh
I have a 2 channel Alpine amp hooked up to the stock non-JBL head unit along with some 6.5" Infinity Reference components in the front. Realizing that the stock deck won't provide you with clean sound, I am still a little annoyed at the electrical "hissing" noise that comes through the speakers even when the radio is off. The loudness coincides with the rise and fall of the RPMs. And yes, I believe everything is properly grounded. Anyhow, my question is, will the Scion HU cure or at least significantly reduce this problem? To those of you with a similar setup to mine, what is the overall improvement in sound quality over the Toyota deck? I know the change won't be anywhere near as good as getting a decent aftermarket deck with a higher preamp voltage, but I still want to keep the stock look and still make an appreciable difference in sound quality.
