Will Tacoma coil lift my 4Runner
blackmobile
Hello all,
I have a 98 4Runner base model 4cyl 2wd. My friend has a 03 Tacoma Double Cab with TRD Off Road package that is a 4cyl and 2wd. He said i can have his front suspension if i wanted it. My struts are blown and was wondering will his Tacoma springs lift my 4Runner? If it will, how much will it lift it by?
TIA
thanks for the quick response.
If i use the Tacoma coils, what do you recommend adding for the rear to make it leveled? How much of a rear lift will i need? It's my daily and i won't be taking it off road.
You could put rear coils from a '99 4Runner. They are about 1" taller than your normal stock springs and that would be about right. Seeing the Taco coils your are putting in the front are used, you could probably go with used '99 springs as well, up to you though.
charlesz
