Will these fit?
496 BB
Will these Tundra rims fit my 1997 4Runner? Both are 16" and i assume same bolt pattern right? Not worried about tires but they are same size as I have now.
Just need some newer looking wheels. Mine look like crap from Ohio salting.
Did you mean to attach a picture?
If they are from an older generation then I'm almost positive they will. The backspacing is probably different though, but they will still work.
Yes & yes & yes to FJCruiser wheels. All three of those choices will work. I mentioned the FJC because all 3 have the same -15mm offset. 4th gen rims have a -30mm and I believe the 3rd gen stock rims are in between the 15 and 30.
What that means is the Sequoia/Tundra rims will stick out a few mm more than OE (assuming that I am right about the stock 3rd gen offset).
On top of that those rims look great:bigok:
