Will these Land Cruiser coils fit?
Those look like 8 wraps unless I forgot how to count. As far as I know they should fit, but I'd wait for someone else to confirm that.
I feel like they look wrong but it could be the picture. You could email him and as for the color code. If it matches up then you know they're right. I don't really understand the 20 in his description either OEM 20 TOYOTA LANDCRUISER Coil Springs
The description says they came off a NEW vehicle. The 20 is probably a typo and the seller could have meant 200 series LC.
What color codes should I be looking for? I really don't know much about the LC lifts other than I should probably go with a 7.5 or 8 wrap. I just recently started looking into these as an option. I was always going to go with OME.
Color code: look at the lift sticky above all the threads. scroll down to lancruiser coil section.
Yep. The lift sticky is your best bet. As far as getting a set you can check classifieds or talk to Irbis offroad/ Slee offroad. I talked to both of them when I was looking around for 9 wraps.
2001ATL
