Will these wheels fit over 231mm 13WL Tundra Calipers & Rotors
TrunksGen3
Hi all,
Just a quick question i you can help? I'm driving a 2000 KZN185 Surf(UK)/4runner.
I have a set of 231mm 13WL Tundra Calipers & Rotors, but before i fit them I want to know if my stock wheels will fit over the Tundra calipers.
surf%20wheel_zpsrmwnqpfa.jpg~original
Has anyone else here fit 231mm 13WL Tundra Calipers & Rotors into these stock 16" wheels?
James
I've not done the TBU personally but I do run those rims in 16s as stock. From my research, they likely fit but if not, you will need a 1/4" hubcentric spacer. I am sure someone will provide you with a more difinitve answer.
Sent from my SM-N900W8 using Tapatalk
Just my 2 cents cdn but look into 5/16" billeted aluminum hubcentric spacers b4 grinding. They should achieve the same goal. You would want to do all 4....
I second this, before grinding.
