window exterior bottom trim ("weatherstripping"?)
Guys:
I was getting out today and my sleeve caught on the black plastic lower trim that seals against the window and keeps the rain out. Its totally destroyed. Great!
I found a writeup on the tacoma boards that said it just gets pulled up and it pops off. Can anyone confirm this is right? Is this auction what I would need?
1996-2002 Toyota 4Runner New Toyota Front & Rear Door Belt Weatherstrip Outer | eBay
Are there clips I will also need?
That'll work, these are the part numbers you need:
68161-35010 Weatherstrip FR
68162-35010 " " FL
68163-35010 Weatherstrip RR
68164-35010 " " RL
68290-35020 Weatherstrip Assy (rear gate)
You can get the whole set from the auction above (without the rear gate seal), it's actually a pretty good price for the set.
Or buy only the one(s) you need using the part numbers above. I replaced my whole set, it was a huge improvement.
They just pop in, no additional clips needed.
Guys:
I was looking at the same auction a few days ago. Ended up only buying the rear left one for $20 used but those are the right parts. They are easy to replace, no clips needed.
